Arlo Pro 2 & Arlo Pro Cameras On A Arlo Pro Base Station
I have Pro and Pro 2 cameras on a Pro Base station, first is there a way to detect what camera is a Pro and Pro 2 within My Arlo. My second question is, do I need to install the Pro 2 Base station to get 1080 on my Pro 2 camera. Currently the Pro 2 camera on the Pro base station doesn't look very clear.
1) It's easier to look at the camera - the Pro has a black ring around the bezel with the Pro 2 has a white ring. Change the camera names in Settings, My Devices, your camera to reflect the type.
2) Make sure the plastic film has been removed from the lens. Post a screenshot or a link to a video for us to see.
I name my cameras with a P or P2 to make id. easy. Remove the battery and look at the label inside.
1080p is a function of the camera not the base station so no you do not need o upgrade.
Check the video quality setting, you may have it set to conserve battery.
