Internet disconnects after 10-20 seconds after connecting Base Station but resumes when removed
  • 1 Reply
  • 639 Views
_12
I have purchased the Arlo  Pro 2 with 4  cameras in USA at Best Buy  in November 2019.  I am in India and connected to internet after going through all the instructions. I am having problem that once it connects to internet router  by Ethernet cable it works only  10-20  seconds and afterwards immediately  internet service will be disconnected. After removing the  cable from the base station (VMB4500) and disconnecting  internet service will be resumed. I have reset the base station but same problem persists,
internet speed is more than 50 Mbps and high speed  reputed one.
Is any software is to be updated ?  Please guide me in the matter.
JessicaP
Hi _12,
I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
  • 1 Reply
  • 640 Views
