Most times when I attempt to login to Arlo iOS App on my Home WiFi it errors with a can’t find server message. Turning off WiFi and using Cell Network works every time without issue. Seen a lot of treads posted about 7 months ago, but nothing resent with any resolve. So I thought about the issue and tried manually setting a known valid DNS Server Setting on my iPhone for the SSID I was connecting to on my iPhone. (Did not have to make any Home Router changes to try this)
I’m now several days later and have not experienced any issues logging into Arlo on WiFi, nor any other Apps I use on my iPhone. Also did not put anyone else on Home WiFi at risk of my experimentation !
Thought I would share if it has any value to others ...
P.S. I only wish the Base Station had a stronger Wireless Signal to reach outdoor cameras further away on property!
If you were getting a msg that said can’t find server and then you turned off Wi-Fi and used the cell network and it worked that tells me that your ISP to your home was down or doing maintenance. One way to check this would be to try to login to your account on a computer. If you continue to see the can’t find server, I would suggest you have your ISP check your lines and let them know your experiencing dropouts.
As far as DNS servers I use https://1.1.1.1/ on my router.
Adding another base station to extend the Wi-Fi range can help.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
