  • 4 Replies
  • 582 Views
gianfrancoss
Su una Telecamera Arlo Pro 2 noto delle discrepanze delle indicazioni di carica batteria tra quanto indicato nella app (100% CORRETTO) e quanto indicato dal collegamento sul pc.
Riscontro lo stesso problema su una ulteriore Telecamera in questo caso una Arlo Pro 3,sulla App risulta al 91% mentre sul Pc risulta in ricarica benche sia installata e funzionante
Dannybear
The web portal issue is related to the local folder cookie from “my.arlo.com” not updating.
The workaround is to continue to use the incognito window each time you login.
If you need to use the normal mode then you will need to setup the browser site settings to only clear data from the “my.arlo.com” site on exit so that the browser allows download of the latest data folder on login.
Dannybear
Translation
“On an Arlo Pro 2 camera I notice discrepancies in the battery charge indications between what is indicated in the app (100% CORRECT) and what is indicated by the connection on the PC. I encounter the same problem on a further camera in this case an Arlo Pro 3, on the App it is 91% while on the PC it is charging although it is installed and working“
Try using the browser incognito or private window mode until it gets fixed.
gianfrancoss
Thanks for the suggestion, I tried to connect incognito as per your advice and everything works perfectly, but when I reconnect normally the problem remains.
Dannybear
gianfrancoss
Thanks, Dannybear, everything is working perfectly now.
  • 4 Replies
  • 583 Views
