Image pixelating on Pro 2
Can you provide a video to better describe the pixelation?
Is the camera externally powered and if so will it resolve if you remove power for a few minutes and reapply?
It is externally powered. I have turned it off using the software function in settings. This along with doing a software restart of the base station will eventually restore the normal video. This is one of two cameras I have. The other camera has never done this.
Try swapping them and see if the problem moves with the camera or stays with the location.
I will. Thanks.
