I can't onboard my base station
A while back my base was showing offline even though the solid blue light was on. I did all the trouble shooting and nothing worked. Finally I deleted the base and did a hard reset. NOW when I go into my phone ap to add a new device I go through the steps of plugging the cable into the router first, then plugging in the power cord and the base comes up with a solid blue light so I know its connected to the wifi but my phone ap says "device not found". I now have over $400 worth of cameras that I cannot use. HELP
Sometimes it will work from a PC (browsing to my.arlo.com), so try that if you haven't done it already.
It is good to know that I could go through PC to do this. I had the similar issue with iPhone 12 Pro Max but then worked fine with iPad Pro for some reason.
