Arlo pro 2 app
I removed the arlo pro 2 icon from iPhone desktop only but did not remove it from library.
Can I get the icon back on desktop ?
Or can I do a complete remove from the library and do a fresh install again so I can get the icon back on iPhone desktop?
You should be able to install the app again, check that it is not already installed on another desktop page already.
Yes. https://appletoolbox.com/how-to-move-apps-from-the-app-library-to-your-home-screen/
Yes I managed to uninstall the apps from the library and reinstalled it to works perfectly
