I can't change my password - It won't accept a new and different password (yes, the password is according to rules).
I have tried on the App and via PC - It replies that it is the same password, which of cource its not.
Jakob2711,
If you're referring to your password for your Arlo account, be sure you're changing to a password you've never used in the past. It sounds like you may be trying to use a previously used password.
Password for what?
Just another user
Jakob2711,
Yes but it doesn’t say that, is says you can’t change to the same password that you currently have. Gah. I hate this. Uninstalled the app because I thought might be a cache problem. But your right off course, it works if you change to a completely new password that you never used. Might be bad translation to Swedish in the app that fooled me.
