  • 5635 Views
Jakob2711
I can't change my password - It won't accept a new and different password (yes, the password is according to rules).
I have tried on the App and via PC - It replies that it is the same password, which of cource its not.
Jakob2711,
If you're referring to your password for your Arlo account, be sure you're changing to a password you've never used in the past. It sounds like you may be trying to use a previously used password.
michaelkenward
Sensei Sensei
Sensei
Password for what?
Just another user
Jakob2711,
wasseng
Yes but it doesn’t say that, is says you can’t change to the same password that you currently have. Gah. I hate this. Uninstalled the app because I thought might be a cache problem. But your right off course, it works if you change to a completely new password that you never used. Might be bad translation to Swedish in the app that fooled me.
  • 5636 Views
