  • 4 Replies
  • 3787 Views
VT-Rider
My 6 camera outdoor system has overlapping fields of view.  When camera #1 detects motion how can I get camera #2, which is too far away to be triggered by the motion, to also record?  The IFTTT app doesn’t seem to do it.
Check out the FAQs and/or a search in the top of screen bar
https://community.arlo.com/t5/Arlo-Smart-Home-Security/ct-p/Arlo
You have to go to MODES, for you base ADD A MODE
follow directions for first camera and SAVE
go back to new mode and edit to add second camera, save
Have you created custom modes?
with rules as follows;
Cam A triggers, Cam A records
Cam A triggers, Cam B records
VT-Rider
Noob here!  I did not know it would be that easy.  But I don’t know how to do that...  Only instructions with the unit were for startup and what is on the package!  Nothing about “rules” in the Arlo app.  Where should I look?
Thank you.
VT-Rider
Thanks.  I also found on line manual!
  • 4 Replies
  • 3787 Views
