My 6 camera outdoor system has overlapping fields of view. When camera #1 detects motion how can I get camera #2, which is too far away to be triggered by the motion, to also record? The IFTTT app doesn’t seem to do it.
Check out the FAQs and/or a search in the top of screen bar
https://community.arlo.com/t5/Arlo-Smart-Home-Security/ct-p/Arlo
You have to go to MODES, for you base ADD A MODE
follow directions for first camera and SAVE
go back to new mode and edit to add second camera, save
Have you created custom modes?
with rules as follows;
Cam A triggers, Cam A records
Cam A triggers, Cam B records
Noob here! I did not know it would be that easy. But I don’t know how to do that... Only instructions with the unit were for startup and what is on the package! Nothing about “rules” in the Arlo app. Where should I look?
Thank you.
Thanks. I also found on line manual!
