  • 4 Replies
  • 1758 Views
Khone
Luminary
Luminary
Yesterday (12/09) I had trouble with my system and had to do a factory reset. Got everything up and running now except I'm not getting email notifications of motion on any of the cameras. Motion being recorded and stored in the library but I'm not getting the email notices like before.
Looked through various Forums but couldn't find a solution. Also, noting in Quick start guide on it.
Can anyone tell me how to set that up?
Edit your mode(s) and then the rule for the camera(s). In there is the place to choose notifications.
Did you check your modes and rules to see what notifications are selected? You say you reset the system so it sounds like you'd be using the default Armed mode.
Khone
Luminary
Luminary
I set it up like before - on a schedule. Nowhere in the mode section is there a place to indicate email notices.
When I go to share, nothing there and if I click Add, then myself, can't save - greyed out.
Khone
Luminary
Luminary
Thanks. Took a while for me to find it. Wasn't scrolling down far enough.
Appreciate your time and help.
Have a great holiday time.
  • 4 Replies
  • 1759 Views
