Can someone tell me how to mount onto the wall with the plastic anchors and screw? Need to drill a small hole with the same size with the plastic anchors? Then?
Thanks a lot
Thanks a lot
How To Put Anchors Into Walls
- Mark your hanging point with a pencil.
- Take a nail-set, awl, or nail and with a hammer tap a “pilot hole” into the wall.
- DO NOT make the hole wider than the anchor.
- Place the anchor over the hole and firmly tap it in until it's flush with the wall
Or
Use 3 M command type strips or auto molding tape and just stick the half circle onto tape
see utube
https://www.youtube.com/watch?v=_G2gCBXy8ZA
