I bought Pro 2 ( 5 ) cameras a couple months ago . Leaning features as I go. It seems I don’t get any longer video than around 30 seconds. Cameras are on battery and motion activated. I would like to be able to extended time after activation. Example of problem I had my driveway camera activate recorded person going on to front porch . Second camera activated for front porch door area and recorded for 20 seconds person was there longer driveway camera again picked up person leaving a minute later. Hoping I can extend video recording.
@TomMac Thanks for your help I was able to finally find were to edit recording. I set recording to max 120 . Will see how this works out . Thanks again!
Sounds like your time setting is "till motion stop"...
many times the cam doesn't see motion and will stop.
You may be better served by a " fixed" time.
edit the mode under recording
I have been trying to find edit recording and can’t find. Can you walk me thru. I do think fix time will solve problem. I just can’t find we’re to change . Thanks again for your help
Read you info, but it did not give details as to how to increase recording time
Read theresponse, but it contained no details as to how to increase the recording time on my arlo vmb4000r3 firmware 1.12.2.4_2772.
Please gie me details as to how to do this.
Read the FAQ here on how to change the recording time in your modes. Briefly, use the Mode tab, click on your base and edit your mode(s). All camera settings are in the rules inside each mode. Be sure to save.
Yea I finally got it to work.
I originally could set the recording time for the ordinary Arlo camera but after having to reset my system I can no longer f8nd where to do it.
suggestions?
By going into mode - armed - and then hitting the pencil to edit, I was able to edit the recording time.
thanks
@Timothy58 I was able to set to a fix time for recording by using app tap mode tap armed pencil then tap pencil for camera you want to change then tap recording video pencil and adjust time then save.
When I chose mode, the pencil (edit) only shows up next to schedule option. It’s on, off or schedule (for times of day to arms the cameras).
I really need to length my times bec the cameras are only catching the backs of people. It’s slow to start or something. Hoping maybe the length will help. Any suggestions greatly appreciated.
Thanks for the reminder to "Save" the setting choice.
You must click"Back", and scroll down to choose "Save".
