How do I create a shortcut to specific camera on Android?
Where do you want to put this shortcut?
Just another user
I would add the shortcut to the fire tablet home screen, to expedite access to live view . At the moment it takes me about 30 second to open the live view and number of clicks.
Until a widget is made available (unknown when/if that will happen) the answer is no. You must use the app.
