I cant adjust volume of an alert and I need something longer than a ding dong to wake me. I'd like to use a ring tone
On iOS, I think you are stuck with default... on Android ( haven't checked in a while ) there were other alerts you could pick from..
Thanks Tom. I am using S9
Add your vote:
Custom alert sounds for Android/iOS - Arlo Community
Just another user
Hey azryno,
You should be able to change the alert sound on your Android S9 device by going to the Arlo app and go to Settings > Notifications.
