Can't find the base and I'm in the same wifi ..
The base must be plugged into a router or range extender using an ethernet cable. You may have to purchase a range extender to plug the base station into but they are quit inexpensive.
Brian
Yes, if the account is in her name, she needs to go into her phone and share it with your phone.
Brian
Have her go into her Arlo app and select Setttings then select Grant Access then follow the instructions.
Brian
Well, you don't share the base but, rather, the devices attached to it.
As noted above, since the base is already claimed by your wife, you can't also claim it. If it needs to be in your account, she needs to remove all devices in Settings, My Devices in her account so you can then set it up on your account. Either way, you can use Settings, Grant Access from one account to the other so all cameras show up in each login.
You can't be granted access to the base station itself but you can be granted to the siren on the base station, which carries the same name as the base
