Camera won’t sync to base station
  • 14 Replies
  • 6988 Views
rvinson25
I have 1 camera that won’t sync to the base station. It was synced up before the battery went completely dead. Since I’ve charged the battery the won’t connect now. I’ve followed the steps and the blue light blinks as if it is synced but nothing after that. Please help.
14 REPLIES 14
Go to camera settings, use REMOVE DEVICE.
Open pull battery / replace
Sync as if new
rvinson25
Nothing. Now the camera is deleted but won’t sync back up. I tried restarting the device and still nothing. Any other suggestions.?
Is the battery charged? Have you tried syncing with the camera powered from the charger? What are the various LEDs on both the base and camera showing?
rvinson25
Battery is charged. Even swapped a battery from another camera. Haven’t tried plugged in yet but figured with a fully charged battery that wasn’t necessary (but I’ll try it). Green LED blinks on the base station. Blue LED blinks slowly for a while then an amber LED blinks indicating the the sync was unsuccessful.
steve_t
Master Master
Move base station a foot further away from your wifi router
rvinson25
I’ll try that. Yesterday after deleting the camera and leaving the battery out of it for most of the day, I put the battery back in the camera registered as if I never deleted it but still said it was offline.
steve_t
Master Master
Have you got more than one base station or has this camera ever been sync'd to another base station?
rvinson25
No, only one base station
rvinson25
Moved the base further from the router and still a no go.
steve_t
Master Master
Bugger. Try turning your wifi off completely for a bit. That'll rule out interference from it but I guess if it works, you have to try something else, possible changing the channel of your 2.4GHz network
rvinson25
I can try turning off the WiFi another day. Would it be worth trying to deactivate everything? Base station along with all the cameras. Reset to factory settings?
steve_t
Master Master
That seems to fix a lot of stuff. I wouldn't expect it to be necessary but I'm regularly surprised about what fixes things in IT 😉
rvinson25
So after trying over and over again to sync the camera. I even uninstalled the base station and started over like new. The camera will not sync. I have to replace the camera. What is the warranty? Will Netgear help with this?
If new enough, swap at the store. Otherwise, open a case with support here for a possible replacement.
  • 14 Replies
  • 6989 Views
