Go to camera settings, use REMOVE DEVICE.
Open pull battery / replace
Sync as if new
Is the battery charged? Have you tried syncing with the camera powered from the charger? What are the various LEDs on both the base and camera showing?
Move base station a foot further away from your wifi router
Have you got more than one base station or has this camera ever been sync'd to another base station?
Bugger. Try turning your wifi off completely for a bit. That'll rule out interference from it but I guess if it works, you have to try something else, possible changing the channel of your 2.4GHz network
That seems to fix a lot of stuff. I wouldn't expect it to be necessary but I'm regularly surprised about what fixes things in IT 😉
If new enough, swap at the store. Otherwise, open a case with support here for a possible replacement.
