How many cameras can I put on each Base Station?
I have 3 different hubs and a combination of Arlo and Pro 2 cameras and hubs, How many camera can I put on each hub? Does having more than 5 slow it down??
The last I heard, 15 is the max you can sync to the base. However, only 5 at a time can stream per base so adding more may not be useful, depending on your circumstances.
Can sync 20 now.... with Arlo Smart Elite
