Does anyone know how to contact a physicals person? I am trying to return my defective product but there isn't a way to contact someone. I have a year warranty but I would like to speak to someone before then.
Buying it from Amazon, they can't help when it's defective. I've gone through all the troubleshooting but no luck.
How do you return or replace an item?
sheila_lynnski,
What issue are you experiencing? If you're able to provide details, we may be able to assist here on the community.
Alternatively, you can contact Arlo support using the mobile app under Settings > Support.
Is there a phone # to call support? I got 3 e-mails saying I requested password reset which I did not make! I have spent well over an hour trying to get an answer - extremely frustrating!
Bikepr,
If you have an active Arlo subscription plan, you can contact support using the Arlo mobile app under Settings > Support For more information, see here: https://kb.arlo.com/000062610/Arlo-Support-Options
If you have reason to believe someone may be trying to access your account without your permission. We recommend changing the email/password associated with the account. For more information, see here:
https://kb.arlo.com/4118/How-can-I-change-my-Arlo-email-address
https://kb.arlo.com/4377/How-do-I-change-my-Arlo-password
