  • 2 Replies
  • 2494 Views
klaatu2u1
Arlo pro VMB4000, that is what is on the sticker on the unit. how do i access the storage on the memory stick on the base station??????? i am assuming it is only by the direct link in my hardwire to router? I am not good at this so instructions need to be simple, cannot find anywhere or i don't know how to ask the question. Any help greatly appreciated! This involves retrieving data for a police case so it's not trivial.
The USB backup is really a backup in that it can NOT be accessed from inside the Arlo prgm.
You must properly EJECT the drive and then connect to a computer with a third party prgm to view videos.
( VLC if a free player and works very well, has screen shots and can step thru frames slowly )
klaatu2u1
Thank you for the prompt reply.  I went through the manual again and figured out it isn't in there as it's not possible.  Was able to view the needed video on my win7 destop no problem after safely removing the USB stick from the base station.
  • 2 Replies
  • 2495 Views
