  • 8 Replies
  • 1560 Views
Doug_MacG
I am currently 3,000 km away from my Pro 2 system and I received notification the my cameras are offline. How to I resolve the problem?
8 REPLIES 8
ShayneS
HI @Doug_MacG
Do you still have your cameras appearing as offline?
Doug_MacG
I have since returned home, but they were both offline for 4 plus days.
I would like to solve the issue in case it happens again.
Edinburgh_lad1
Hero
Hero
Very good idea. I'd like to add my name under this.
ShayneS
@Doug_MacG
Do you know if you happen to have an internet outage or power outage in your home/area during this time?
Doug_MacG
There were no power outages or internet issues while we were away.
ShayneS
@Doug_MacG
Thanks for the update, if it occurs while you are home we can investigate this further. I have seen some users recommend a switch to cycle their power on and off for a given accessory.
Doug_MacG
If the system goes down while I'm home it can be fixed.
My question is how do I resolve the issue and re-connect while I'm away.
The system becomes useless and that is not what I want or need. This effectively makes the equipment paper weights.
ShayneS
@Doug_MacG
If the base station or Smart Hub is in an offline state, it will need to be manually rebooted if a restart within the app device settings does not resolve the issue.
  • 8 Replies
  • 1561 Views
