How do I disable notifications?
How do I disable notifications, online it said go to settings then smart notifications. I don’t have smart notifications. It’s windy back there so it’s beeping every minute. I can only see where I can disable it from 30 minutes to 24 hours
Usually for me it’s the sound detection that gets triggered by wind.
The triggered events are controlled by the camera rules set with in the mode menu.
I created a custom mode for windy days that I switch the mode to.
If you’re using the latter app interface you cannot use custom modes anymore unfortunately.
