How do I see the camera names in the library recordings on that iOS app? Currently on the Android app, I can see the camera names on each recording.
oml1200,
Camera names are not displayed on library recordings when using the iOS app. However, you can select a filter for a specific camera to identify which recordings in your library came from which camera. Take a look here for more information on how to use the library filter: How do I use the Arlo library filter?
oml1200,
