How Do I Stop Notifications From Pets?
  • 5073 Views
Chipotle1
How do I set up the system where it is not picking up every movement that my dogs are making. I can end up with hundreds of emails notifing me of this.
Thanks for your help
AncientGeek
Hero
Hero
You will have to adujst the motion sensitivity in the Armed Mode (or whatever mode you are using for Armed)   It may be difficult to tweak so that it doesn't trigger on pets, but still triggers on humans...depending on how large your dogs are.
Chipotle1
Thanks for the suggestion. I need to continue  tweaking it , so far it is still picking them up (they are small dogs) I am at 25%.I will keep you posted
It's possible repositioning the camera is needed, too. BTW, you are changing the sensitivity setting in your modes and rules plus saving, right?
  • 5073 Views
