Dear ms/sir, Please advise how to set siren feature in arlo pro 2 camera.My base station model is VMB4000r3. Siren option is seemingly unavailable. Regards Robertwee
The siren is available at the top right of the iPhone App. Red circle with white shield and red exclamation mark.
You can use this to manually trigger or to acknowledge the alarm.
To enable the siren to activate with a detection event on a camera, go into the mode you intend using and edit the camera rule to add a new device and choose the base name. Follow the prompts to set loudness and enable alarm. Hope this helps.
As noted in the previous reply, you have to edit your modes and rules to do this. Read the FAQs here on modifying and creating modes/rules. In this case, you would edit a rule for the camera(s) desired and use Add Device in that rule to add the siren to alert when the camera detects.
