Stands to use when installed to roof
What is the most practical stand when installation should be on roof? (As those magnetic ones not necessary works)
I’m looking very flexiple solution where camera direction should be easy to change.
There are many camera threaded mounts you can use for this. Arlo has several options and Amazon has tons of options. Look for ones that use a 1/4"x20 thread which most have.
Thanks a lot.
