How Do I Change Modes From Android App
How do I chance the Mode from the Android App. When I select the base, it flashed green, then nothing happens... it opened the various mode options window one time like 2 weeks ago, but I have not been able to do it again since.
Thanks in advance!
You go to modes, then pick base, and the armed/disarmed option should appear...
If not, then test the system on a browser like Fire fox ( https://arlo.netgear.com/ ) to see if it's the system or app/phone.
Also, you can uninstall the app and re-install it and retest
