I am attempting to use the Geofencing feature of my Arlo system. I would like to set this up for my wife's phone and my phone. However, under the summary of "Enabled Mobile Devices" it is saying there are 3 Enabled Mobile Devices. When I click on the "Enabled Mobile Devices", it only shows our 2 phones.
The problem is that the 3rd phantom device is causing the app to believe that we are always home. Thus, geofencing does not work. Is there any way to remove this phantom device?
I am assuming that the phantom or hidden device could be my wife's old phone which was destroyed. Even if this phantom phone cannot be removed, can I disable it somehow?
Do you have the latest version of the Arlo mobile app installed? You should be able to navigate to Mode > Select desired device > Geofencing Pencil icon > Enabled Mobile devices > Edit > Delete (Red Trash icon) > Continue > Done > Back > Done.
Dannybear,
I do have the Edit label in the top right hand corner of the app. When I click it, the 3rd device does not show up for whatever reason.
ShayneS,
I believe I am using the latest Arlo mobile app version for Android. The version installed is 3.5.13_28425 that was released on 1/25/2022. When I do navigate to the location you specify, the 3rd device does not show up on the screen. Only the my phone and my wife's phone. The 3rd ghost device is still missing. I have removed the tick from the check boxes for both phones under "My Devices" on this page. When I go back it still shows a mystery device as being enabled. It is like there is a ghost device that has not been completely removed for some reason.
Can you try and reconfigure grant access (remove and re-add) to see if that fixes the problem?
I have the same thing going on. Enabled mobile devices is three, but only two are listed.
Things I have tried:
Deleting cache and data for Arlo
Uninstalling and reinstalling Arlo
Deactivating 2FA for all devices and reenabling.
Removing trusted devices and re adding them.
Can you try to (remove and/or re-add the granted access suer) to see if that fixes the problem?
I don't have time to do what you're asking. My geofencing is not working and it is definitely an error in the coding of the app. I think I'll just cancel my membership and go with a different camera.
That'll take a lot more time than doing what's suggested.
It'll be worth it to have a properly-functioning product.
Terrible coding on the app has been an ongoing issue. Slow to load feeds from cameras indicates suboptimal hardware. The system was not worth what I paid for it. Security is important, and it should work well. Arlo doesn't achieve this for me, and reading reports from other users, many agree.
I too have tried to remove and re-add granted access users. Other than telling where to remove devices, I don't see any further suggestions. Did I miss other suggestions to try?
