Hello and hi 5 2 all Arlo Community !
1. Here are my preconditions and stuff:
a) Arlo products
- VMB3000 - used, reset, off;
- VMB4000 - used, reset, is now on, paired with VMC4030P x 4, and wired to Dir-825, has it's own static LAN IP appended (manually), power, web and cam - solid green;
- VMC3030 x 4, VMC4030P x 2 - all used. Arlo Pro 2 series weren't syncing to newer base (VMB4000) neither in offline nor in online mode (being around half a meter from base), so base and cams were manually reset (I hope so) following instructions from here, and batteries were all out (all charged using original charger).
These Products are all sent from U.S. to our summer house in Ukraine this year.
b) LAN conditions:
- optic fiber line in (up to 1,25 Gbit/s), ONU E-PON;
- current data plan - 100 Mbit/s;
- paid static IP;
- D-Link DIR-825, already set up and running Wi-Fi at Channel 1 (2,4 Ghz) in B/G/N mixed mode, SBTC on. Real Wi-Fi to WAN/Web speed (incl. all transmission obstacles and LAN to fiber commutations) is around 30 - 50 Mbit/s.
2. Then, first set of 4030p x 4 cameras were easily paired to VMB4000, passed in-app push message confirmation on iPhone 8 (backup security) and Free Arlo account registration. Now, they are all set in Main room.
2.1 But, the problem is :
I'm unable to register other cameras (using iPhone XR) through push message security confirmation dialog (for Guest room). it's grey and un-tapable (Arlo app is freshly installed) and Ukraine is not in the list of SMS-enabled countries (while Moldova, Belarus and Russia is there).
Dear Developers, please add Ukraine as SMS option during in-app registration (as it is present at Arlo Community registration page), so that I can register and log into my Arlo account (app) using Ukrainian mobile number and mobile data provider (while out from the house, but guests are in so...)
2.2 Is it possible to log out from push-enabled account on iPhone 8, and register another account through SMS using Ukrainian phone number (as push message security/trust option is now also blured on that iPhone 8 during New Arlo account registration) ?
p.s. - all phones currently work well with Ukrainian carriers, and SMS from other US services like Amazon and Qualcomm are well received.
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Tried several times... ones Laine connected, but then suddenly dropped.
What's going on with Arlo Live Chat Support?
Could you please pass my issue directly to Tech/Dev Team for a review ?
p.s. check timestamps !
Hi sshyran,
I have opened a case for you. Customer Support will be reaching out to you as soon as possible. I have provided the case number for your reference: 42566769
