Each morning Arlo will not move to the next date. You have to log out and log in again to make the system work.
I would try a simple power button reboot of base... turn off then on wait 2+ mins to fully reset
Are you talking about accessing the library? The app will remain on the last date you accessed. But you can manually access recordings for the current date (w/o logging out).
