Had to change routers due to Internet issues and now Base Station won't connect?
Had to change routers due to internet issues, now our base will not connect to the Arlo app and our system isn't working, can someone help? We have reset, we've uninstalled and reinstalled and nothing is working, any help is appreciated
Try using a PC (browsing to my.arlo.com). That sometimes works when the app fails.
It's unfortunate that you googled for support rather than using the tools available via the app (Settings, Support) or web (Support link at the top and bottom of these pages). Arlo doesn't charge a thing and will NEVER take over your computer. Stories of things like this are all over with strong warnings to not fall for them.
@BeardFamily Have you used the chat in the support link below below the last post here as suggested since you can't get to your settings? You never said if you tried a suggestion of using the PC to connect. This is a user to user forum so not sure why you are attacking people trying to help or prevent you from paying a scam.
