  • 5 Replies
  • 971 Views
BeardFamily
Had to change routers due to internet issues, now our base will not connect to the Arlo app and our system isn't working, can someone help? We have reset, we've uninstalled and reinstalled and nothing is working, any help is appreciated
5 REPLIES 5
Try using a PC (browsing to my.arlo.com).  That sometimes works when the app fails.
BeardFamily
We have used pc we have also been told that Arlo did an update and now it will cost an additional $150 for them to take control of our PC and update it, which is ridiculous! Our system has always worked since the day we installed it and then when we have to change routers all of a sudden it doesn't work anymore, that's insane! Thank you for suggesting the PC, but we have already done that
It's unfortunate that you googled for support rather than using the tools available via the app (Settings, Support) or web (Support link at the top and bottom of these pages). Arlo doesn't charge a thing and will NEVER take over your computer. Stories of things like this are all over with strong warnings to not fall for them.
BeardFamily
Ok where is the help? Being as I can't get into settings under my account,I have to use Google to get to the Arlo community, and then I get responses like yours! Instead of a solution and actual help, and it would have been mis fortunate had we have been stupid enough to give someone control of our computer, I came here for help and seem to be getting the same run around, this is ridiculous!
dcfox1
@BeardFamily  Have you used the chat in the support link below below the last post here as suggested since you can't get to your settings? You never said if you tried a suggestion of using the PC to connect.  This is a user to user forum so not sure why you are attacking people trying to help or prevent you from paying a scam.
  • 5 Replies
  • 972 Views
