HW VMB4000r3, Firmware 1.12.0.1_27940 - Schedule Mode Problem
Following the noted firmware upgrade, my Schedule mode for nighgtime goes to Disarmed. Any help would be appreciated!
At least temporarily, use only a web browser to check/set anything under the Mode tab. You can use a mobile browser if set to use the desktop version of the site. Once logged in on the browser, check everything - your modes, rules and schedule to make sure everything is correct. Then NEVER use the app to check or set while testing to see if things stabilize.
