I am not sure how you are set up with your modes and rules. Check them out carefully, and you hopefully see what is going on.
But, why not simply disarm the system or cameras when you are home, of if your schedule is regular, set up schedules to disarm the system when you are home.
Brian
My experience with geofending – Q Plus and Pro 2 – is that it is decidedly flaky. That's a technical term for "doesn't always work as expected".
It often fails to notice that I have come home
Just another user
Since your home wifi must communicate with Arlo's servers and then Arlo's servers must communicate with your phone and them back to your home wifi, all through the cloud, I would never depend on geofencing to arm/disarm my system. I have often had over 30 minute to 1 hour delays, (depending on how the cloud feels at that particular moment), and often have had my wife's phone listed as present all day even though she was at work with her phone.
Brian
