Ever since the most recent update, the geofence does not work correctly for my Arlo pro 2 base for my wife’s iPhone. My iPhone still shows location, but her phone shows “unavailable” for the pro 2 base.
Our Arlo smart hub 5000 and two light bridges both work for her location, it’s only the pro 2 showing “unavailable”.
I have tried the following steps...
-Rebooting phone
-force quiting the app
-hard boot the phone
-Turning off the location for the device in Arlo app then turning back on
-turning off the app location a ettings of phone and resetting back to “always alllow”
-restarting and hard booting again after all those steps
Anyone else having similar geofencing issue since most recent update?
Did you happen to try and remove and re-download the Arlo app?
I will try deleting and reinstalling this evening...
Okay, thanks for the update. Arlo app v3.0.1 is out now, so hopefully that update/re-install might remedy the issue you are experiencing.
