Geofencing Reversed When Home
Geofencing sets away when I drive down the road. When I get home it sets to Home (schedule) and then one minute later sets to away again and I get alerts all night long.
I have this problem too.
I didn't clue in that the geofencing was switching back to "away" after a time though because the system does acknowledge the initial transition to "home".
I thought the system was just sending me notifications regardless of the setting, but your diagnosis makes sense and aligns with what I am seeing too.
Glad I am not alone, but hope Arlo fixes this soon.
I will add that I had originally purchased the Arlo Pro (1) after Christmas and this did not happen. I was so impressed with the Arlo Pro that I upgraded to the Arlo Pro 2. Unfortunately, my experience with the Pro-2 has been buggy. This geofencing issue plus I have to reboot the system weekly because some setting or another stops working.
Hello @Chrisizzle @pilotchip
Have you tried rebooting your base station & test again? What firmware version is your base station running? Do you have any power saving modes enabled on your device?
HW Version: VMB4000r3
Firmware: 1.12.0.1_27940
Pro 2 v2.7.0
App is "Not Optimized" under Android settings.
What's the best method for power cycling, just unplug power cord?
I seem to need to reboot the Base Station weekly. I've tried a number of Geofencing scanrios. It basically always stays on "armed" regardless of whether anyone is home or not.
My apps are on iPhones. The app / Arlo correctly knows when people are in/out of the geofencing zone.
No power save modes anywhere.
I would suggest pressing the power button on the back of the base station. we can start with that if you have not already.
Can you also try the new Arlo Mobile App Version 2.7.1.
App version is 2.7.1_23406
Rebooting the base station and will report back after testing for a few days.
My problem is (mostly) resolved.
I was contacted by someone from Arlo tech support as a result of this forum post. We spent some time on the phone and I think we narrowed down the problems.
The first thing to try is opening the GeoFencing settings and moving your "home location" away from your actual address. Save those settings. Then, re-open the settings, properly enter your home address and save again. That seemed to solve most of my issues. (Essentially, reset your home address)
GeoFencing now works fine with me (administrator) and my phone.
All the technical issues I had reoccur when I try to add my girlfriend to Geofencing. She is not setup as an Admin and I don't know if that would make a difference. I think the overall problem is due to her phone. She is still using an iPhone 5s. For any number of possible reasons, her location occassionally shows as "unavailable" in the geofencing settings. I think that messes up the Arlo settings and it goes into "Armed" as a precaution since it doesn't know whether that person/device is home or away.
So, if you are trouble shooting, start with your most reliable device and just test geofencing with that.
