I’m new to the Arlo family so my question is my front camera picks up Motion but my back camera I cannot seem to get that camera to pick up any type of motion I’ve gone through and take my motion detection and everything some reason I’m having a hard time getting that particular camera to work for me
So to clarify, you performed the motion test process using the motion test utility in the camera settings on the app and was unable to detect motion.
Firstly try resetting the camera, remove any external power if attached, then remove the battery for 10sec and reinstall and test again.
Thank you, I’ll try that.
