  • 4 Replies
  • 1861 Views
Herm
I inadvertently set up a "False Device" in the process of initial setup of my system. I have not been able to delete this device. Can this be done and can anyone offer a solution?
Are you referring to the "second base" listed in My Devices? That's the siren and is there so you can name it for your own purposes.
Does it ( the device ) show up in settings?
If so see if Remove Device is there.
If not, you may have to remove all cameras and then the base, do a full reset ( hold reset about 10 secs till led flashes )
then reclaim base and add cameras as if new.
Herm
It does indeed show up and it can not be removed.
I had thought of your solution but did not want to go to all that trouble. I was looking for a simpler solution.
I may just leave it there as it causes no problems.
Thanks for your prompt reply.
What fake device did you setup....?
  • 4 Replies
  • 1862 Views
