There is an extension bolt that is included with the WMA4900 Power Adapter. Where can I get just the extension bolt or is there another part that someone has come across that can be used for this purpose?
Thank you.
You could try contacting support: https://www.arlo.com/en-us/support/contact.aspx
The threading is standard, so if you see a similar camera mount extension somewhere on-line you could also do a risk-buy.
