How do I get hold of one of these having one falling out after two weeks of purchasing my Arlo pro 2
Unfortunately you can't. You can try exchanging the camera I guess. Some have applied some silicon grease around the seal (not sealant!).
Though you might try pushing it into place (using a paper clip or some other aid). That works for me.
