Rubber weather seal protecting charging socket on camera
  • 1 Reply
  • 1175 Views
Patham
How do I get hold of one of these having one falling out after two weeks of purchasing my Arlo pro 2
Unfortunately you can't.  You can try exchanging the camera I guess.  Some have applied some silicon grease around the seal (not sealant!).
Though you might try pushing it into place (using a paper clip or some other aid).  That works for me.
  • 1 Reply
  • 1176 Views
