Drive Hooked Up To Base But I Only See The Last Week Of Recordings
  • 5 Replies
  • 2300 Views
Lenji
I have a 1 TB drive hooked up, selected local storage, yet I can only see the last week of recordings.
Any ideas?
michaelkenward
Sensei Sensei
Sensei
Does "hooked up" mean plugged into the base station? 1TB may be bigger than it can accept. Did you test it?
In any case, you cannot use the Arlo interface to see stuff stored on the USB drive. As @jguerdat says you have to eject the storage and use something else to see the recordings.
This is what the User Manual says:
Video clips on USB storage devices do not display in the Arlo app, but you can use a
Windows-based or Mac computer to view the clips.
Just another user
5 REPLIES 5
On the drive after you safely ejected it and viewed on a computer or in your library?
michaelkenward
Sensei Sensei
Sensei
Just another user
In theory, the base ( Pro/Pro2 ) has a max drive of up to 2 TB.( TMK )
Lenji
I am only looking at it through the app currently
Lenji
I see, thank you for sharing that info.
  • 5 Replies
  • 2301 Views
