Does the housing help cut down wind. My Arlo keeps setting off because of wind
If you mean the skins to cove the Pro2 , then not really.... tho it might slightly since the mic is in front
More of a way to change the color.
What about the housing that looks like a birdhouse??
The microphone is on the front surface of the camera, so it would still be exposed to direct wind from the front.
Wind from the side or back would take a different path because of the housing - no idea if that would create more wind noise or less, since I don't use that housing.
