Does the current arlo pro v1's battery and accessories work with the arlo pro 2?
i've been in the market to purchase a set of arlo pro, glad the announcement came in time, but wanted to see if all the accessories are backwards compatible?
Yes, accessories and batteries from the Arlo Pro are backward/Forwards compatible, including the Arlo Base Station
Please click KUDOS or REPLY If you found this helpful.
BretD wrote:
MMakoto wrote:i've been in the market to purchase a set of arlo pro, glad the announcement came in time, but wanted to see if all the accessories are backwards compatible?
thanks Bret. the arlo pro 2 has mentioned about continuous recording when used indoor via a cable, what kind of cable is that? does it come included?
btw, am i automatically entered in the arlo pro 2 sweepstakes? i wasn't quite sure if i need to ask a question from within one of your threads or start a new one?
Thanks for asking your question. Yes, by asking a question here, you are now entered to win, Good Luck!. The USB Charging cable and adaptor is what is needed for CVR, but it also requires a subscription to the CVR service.
- (1) Indoor power adapter
- (1) Indoor power cable
is it a micro usb cable? what's the length for the one that you sell? also, do you know the price for the CVR?
