New Zone Feature work on Arlo Pro 2?
Will the new Arlo Pro 2 zones work similar to other security camera systems? I can't recall if my VueZone had zones or not but I know the Arlo Pro 3 camera system I just bought (yes :() does not have it.
Some features such as 1080p resolution and zones require the P2 to be AC-powered due to power considerations. Yes, you can use zones with the P2 as long as it's plugged in. The solar panel won't work for this.
