I have two systems in separate properties and want to add additional cameras. Do they still make the Pro 2 cameras?
No.
This says they stopped making them in Dec 2019:
Stephen, thanks for the reply. Do you know what model is compatible with the base system for the Pro 2?
Many current models (all Essentials, Pro 4, Pro 5s) can connect directly to your home wifi, and don't need a base.
There are several bases that were sold with the Pro 2. Base station compatibility info is here:
Look for a VMBxxxx label on your base.
Note that all currently sold cameras will require a subscription to get cloud recordings. Arlo stopped offering the 7-day cloud recordings you get with the Pro 2 on new models back in 2018.
