  • 1 Reply
  • 781 Views
Armendariz5
hi when I have the camera plugged into the electric plug do I need to have the battery in the camera, or could I remove the battery and is it safe to take the battery out and just have it plugged into the wall
Best answers
  • StephenB
    Arlo says you can do this either way.  If the battery is inserted, then of course the camera will continue to work if the power fails.  But if that is not a concern, then you can just take the battery out.
    If you live in a very cold climate, you probably should remove the battery in the winter, because the camera will run at a lower temp w/o the battery.
  • 1 Reply
  • 782 Views
