  • 1 Reply
  • 1094 Views
Ronniev1952
I have two separate base stations in two different states. Do I need separate accounts for each one or how do I use both locations for one sign in?  Thanks
If you migrate to the "Feed" interface, then you would be able to set up two different locations.
The downside is that "Feed" has some issues.  It has no custom modes (just three built-in ones - Armed Home, Armed Away, and Standby).  These can be modified from the app.  Also users have stuggled to get geofencing and scheduling to work.
  • 1 Reply
  • 1095 Views
